HR214 ... HOW TO REPLACE DRIVE GEAR and BELT
Honda HR214 have no belt ,do you want to replace transmission ? or repair the gear inside transmission ?
Shows you how much I know … My initial response is replace the gear … How to I do that? Mower just stopped moving forward. Engine runs great. Thanks in advance.
Look for cable first,there are 2,one to shift gear,another to engage the transmission
adjust the cable,the one with spring how when you engage the arm move all the way
Adjust the nuts …. lifted up mower and wheels turn …. however when I put back down its not strong enough to move mower … makes a ratcheting like sound
So problem is the ratchet ,use 14mm wrench to remove the wheel,do it one at time so you don't mix left wheel and right wheel .There is a spocket like in picture .Bent the wire to make the 2 teeth bending out,fill them with greese then put them back .the wheel should turn free when you turn forward and engage with shaft when turn back ward
