hello, new to the site.
I'm having trouble with my #936061 mower. When I shift it into neutral, it doesn't disengage thee transmission. also it has a vibration coming from the rear too.
Is there a way to check the fluid level on my select gear drive transmission? also i read that someone else bore a hole in the top to check the fluid. Where and what size?
I'm a newly when it comes to my mower repair since I just recently purchased a new mower deck drive housing. my mandrel was sheered.
Thank you
Thank you
