How to remove the coolant Temperature gauge
Fatdaddy
Kuboa Diesel ZD326 60" 700hrs ,,,, The gauge stopped working, i got a Sending Unit to replace it but nothing still does not work..
Can I ASK how to you change the gauge? Do you have to take off the whole cover to get to it?
Anybody have any tips on how to do this?
David
Tennessee
BlazNT
4 or so screws that hold the instrument panel in place. Remove and lift up.
dpigguy
The 326 uses the same gauge as my 323. You can avoid pulling the instrument panel by simply pulling the gauge straight up and out. You may need to pry it up with a small screw driver but it will come out far enough to get to the wire harness. Goes back by pushing it in place. You can always pull the panel up as well but I found pulling just the gauge worked as was an easier process.
Just a thought, make sure your connector at the sending unit is firmly attached. My oil send unit quit working and I found the wire had pulled out of the connector enough that it looked okay but was not making contact and completing th e circuit.
Fatdaddy
Thank You GUYS FOR HELPING ME... It did work got the cover off and had to pry it up but it came off and pulled out...
I should have tried it but did not. i can screw things up make it worse..
I just hope this is my problem, I replaced the sending unit and now this..
If not this don't know what is next
They did not have one but got one on order
Tks
David
