Larry Upnorth
- Aug 5, 2011
- 1
- 2
Hi,
I have a Snapper 150Z, 50" cut zero turn with 20 hours on it. I would like to remove the deck for a thorough cleaning and blade sharpening. Owners manual makes it look pretty easy and I've removed decks from other mowers many times in my 50 years. Problem I'm having with this unit is un-hooking the back two brackets. Pulled the hair pin, but the pin from the top bracket is attached to the bracket itself, and there is not enough play in the bracket to push it inward to have the pin clear the hole on the deck bracket. Anyone run into this? Thanks, Larry. PS, this is my first post here!
