How to remove clogged/broken fuel filter screen in gas tank?
Mmoore234
  • / How to remove clogged/broken fuel filter screen in gas tank?
BS 09p702 engine / craftsman m220 push mower
I have a fuel tank and it has one of those built in fuel filter screens in the tank thats is clogged and has a hole in it already. I tried removing it but ended up clogging it even more.
Is there a way to remove it without damaging the tank? I have fuel hoses with an inline filter i want you to use. I tested it with a new tank from another mower it works very well but that tank is to big to fit
Auto Doc's
Those filters have to be the trickiest way yet for engineers to cause problems with small equipment. Any trash that gets into a tank when refilling immediately blocks them.
The parts diagram only shows the entire tank for the economical sum of $124.99 on Parts Tree.
The "pencil" style filters are shoved into the tank outlet nipple. There should be a fine separation line that indicated the rim of the filter tube at the end of the fuel nipple. Take some pliers and gently squeeze it a couple of times and it will start to come loose. Once loose, the filter can be pulled out.
Option #2 is to ram a pocket screwdriver or a section of coat hanger wire through it and leave the remains in place. That will let fuel flow for the new line and inline filter.
sgkent
my understanding is they are attached to the drain or tank valve. Usually they come with a new drain or drain valve and are screwed in, or sit in a neoprene grommet. Most of that stuff is on Amazon. If the sock is plugged, it could mean it is time to drain and clean the tank.
Mmoore234
I ended up buying another tank on amazon for $35 still what a crazy decision to have a fuel filter built in the bottom of the tank. On the BS site it even says the in tank filter is “non-serviceable” . So now customers have to buy a new $125 oem or poor quality after market every time the tank clogs?insane Lol.
I also tried your suggestion unfortunately that screen is tightly sealed into the tank even after an hour of picking at it i was unable to remove all the bits of the screen and was worried at some point in the future a piece or two might break off and clog it again so i just bought an after market one instead.
outdoorpowermike
Maybe if you have enough room just add a small inline fuel filter with new hose and hose clamps.
