I have a 2007 yard machine with a 17.5 hp B&S engine. Model # is 31c707.
I have had several problems with this mower that I worked thru given advise from the forum. I am down to; starts but runs really rough and goes thru gas like crazy. I was advised to test the fuel solenoid and clean the carb. I have remove the fuel solenoid and am waiting for any remnants of fuel to evaporate before I try to test it. While waiting I want to remove the bowl and clean. I expected the bowl to pull off with a few light taps but it doesn't budge. Are there screws/bolts holding it in place?
thanks
thanks
