Snow blade How to keep an X300 running through the winter
MichelleWieFan
Hello, I have a John Deere X300 riding mower. I have decided to put a snow blade, weights, and tire chains on it this winter to help me with snow plowing/snow removal at home. My question is: What should I do (or buy) to make sure the mower will start and run when I need it to? I had planned on starting and running it every few days, but thought I'd ask if there are other options available. Thanks in advance for your assistance. have a great day!
I had an old Kohler engine that was very hard to start and put up with it for years. I bought a new starter and I couldn't believe the difference at the cranking speed and how quick it would start after sitting for a year.
It has to do with the compression release built into the engine I believe. Don't know if this is your problem but cold weather and a slow cranking engine means hard starting even with a good battery.
Other than what is mentioned is a magnetic oil heater that sticks to the oil pan to heat the oil.
