how to get plug wires thru
klockk
hi, am replacing my b&s magnetron,but don't see how to ge the plug wires thru w/out removing flywheel.it's a jd model116 with a 16hp b&s.any ideas?thanks
mechanic mark
Google: how to remove B&S flywheel, watch utube videos.
klockk
OK.got that figured out.Now I have replaced the magnetron coil.ran good till it got hot then no spark.put in another magnetron coil and it ran good till hot.any ideas?loc
mechanic mark
Post all engine numbers including code: model xxxxxx, type xxxx, trim xx & code. Are you using B&S OEM part? Not aftermarket? Also clean engine by hand with shop rags or towels, I prefer using a shop vac after loosening everything up, crud, dirt, etc. Also check air filter for replacement as well as changing oil & filter if oil is black. Make sure underside of flywheel is clean & nothing stuck to magnets.
