How To Find Out What Year Mower Is?
Any Scag dealer when provided with the serial number of the machine can tell you within a two year bracket what year your machine is. But a better clue will come from the engine numbers as all engine maunfacturers have the engine build/manufacturer date included in the engine numbers. The service manual for the make and model of the engine will tell you what the engine codes mean. The engine would have been built/manufacturered at some time prior to the assembly of the machine. If the machine has been repowered then the engine numbers are not indicative of the machine year.
Mad Mackie in CT
In the power equipment world, correct model identification and serial number are important. This is also true for engines and other major components such as hydraulic pumps, motors, hydrostatic drive units, and electric clutches.
Power equipment manufacturers generally don't follow the typical automotive pattern of major changes with model years.
I purchased my Scag Tiger Cub in August of 2008 as a new unit. The B&S engine was manufactured in mid 2007 and the machine serial number indicates the same time frame. This machine serial number group is the latest of the Tiger Cub models. Now that the Tiger Cub has been changed to Tiger Cat, the serial number groups have changed to reflect this change. The machines are very close in actuality except for the ROPS protection being hinged on the Tiger Cat models and ridgid on the Tiger Cubs.
Mad Mackie in CT:biggrin::laughing:
