How to change drive belt on Troy built self propelled 12av566n711-183621
Mowdan
  • / How to change drive belt on Troy built self propelled 12av566n711-183621
jsm0960
Pretty easy really. Take the transmission cover off over the front wheels. Next tip mower up and take the blade off. The trans assembly will move towards rear of mower enough to disengage it from the pulleys. Feed the belt through to underneath the mower. Install new belt reversing the directions I just gave you.
