How to access steering arm switches for Z254 ZTR
bcarwell
How do I get access to the steering arm switches. What needs to be unbolted, what strings or linkages disconnected ?
I can provide some pictures if helpful.
The engine starts and runs fine but as soon as I bring the steering arms in to go forward the engine dies.
I was told it was probably electrical corrosion or loose switch connections.
I can FEEL what seems to be a linkage or switch very loose and moving around if I put my finger in the hole where
the LEFT arm goes down through the hole under the cover. The right side components don't feel loose like this.
Bob
