Walk behind How old is my mower?
Toad
I have a Western Auto Wizard walk behind wheel powered. Mod 110988 Type 0381-03 code 82021124. Its a 22 inch cut. I cant seem to find anything on the world wide web. Anyone out there lend me a hand?:thumbsup:
earthworm
Pics may do the trick.
I can't spell pictures, nor can I electronically "take" 'em.
And, I guess WesternAuto did not survive the cut..
The B&S engine was built in 1982.
Toad
I managed to find out it is an MTD badged under wizard Model MTD6441A23 but so far my leads have dried up. Oh great ones of the lawn help me on my quest of finding some enternet links.:confused2:
Mini Motors
I doubt seriously that the engine sat around any before being installed. BTW, the engines exact birthday is Feb 11, 1982. So I'm not sure what else you want. I can tell you what the engine model number equates to, but it's stuff that's fairly obvious.
11= CID
0 = Basic Design
9 = Vertical Shaft/ Pulsa-Jet carb
9 = Auxiliary PTO, Parallel to the Crankshaft
8 = Vertical Pull Starter
Toad
Thanks! That is what I was needed. This is a great site. Cheers!
