How do you test a fuel pump?
Hardluck
Badboy Kawasaki FD731V72106 FD731V AS09 How can I test the fuel pump. The emgine area is making a slight grinding or spinning sound with the key on that I don't think it used to make. The engine is not runnning at the time.​
Engine only running for a few minutes and when it gets hot or warmed up it will die and you have to wait for a few minutes fuk chick to get it stated and then only runs for a second or so. Thank you.
