Fuel Hot temp fuel stops flowing
dixbrown
Above 80 degrees air temp the fuel will stop flowing after mowing for awhile. No fuel in the filter. It will start after about a half hour. It is like a vapor lock. The fuel line insulation is intact. The tank is clean. A friend has the same problem. Model 2166 Kohler engine. Help
cpurvis
Sounds like a fuel pump issue.
