Hello, richnfla,
First of all, a remote-controlled (RC) hill-climbing lawn mower is definitely a viable option, especially when you can no longer use a ride-on mower. You’ve made the right choice! However, there are a few more points to consider: if you’re using it on a delicate lawn, a tracked mower carries the risk of scratching the grass; but if you’re using it in areas with thickets or overgrown weeds, it’s absolutely perfect. For lawns, we recommend choosing a 4-wheel-drive model with a climbing ability of around 30 degrees. Also, be sure to ask the seller whether the drive motor is brushless or brushed, as this will determine the machine’s service life.
