HONDA RF500
knr2
I just acquired a HONDA RF-500 tiller and started it up yesterday. It only ran about 5 minutes and spewed white smoke out the exhaust and had no power. I quickly shut it off and now the crankcase oil is saturated with gasoline (About 50/50) and the air filter was full of oil. It started easy 2nd pull. Any ideas here would be helpful. I'm not sure if I should just drain oil and try again or if there was an adjustment on the carb I could make to prevent this from happening again.
