Honda NeXite hrx217 side dischrage
tcpuccio1
does anyone a source for a side discharge chute that will fit the honda composite deck mowers. Sick of the rear discharge filling up my boots with gras clippings. Looks like Honda doesn't make one for these they must not see the flaw in this design. is there any after-market choices for a side discharge?
my mowers full model # is hrx217k6hyaa
Switch the chute from bagging to mulch. As for a side discharge option I have never seen or heard of anything made.
if it has a side opening with a door, you could use it but if you are talking a plug in that is 90 degrees, the resistance would be too high. You might find a mulching plug and get a mulching blade as others suggested.
He wants a good mower that will not fill his shoes up with grass and rocks. I've seen guys push way off to the side with that crap Honda rear trap door mess wide open. Freaking hilarious!!
Ya..close the rear chute, cut a hole in the side of deck. https://www.amazon.com/toro-side-chute/s?k=toro side chute
