Honda lawn tractor 2113
msbehnke
Hi folks, first timer here! My Honda lawn tractor has stopped and I'm baffled. I have good voltage from the battery to the starter. All safety switches were replaced last year, and are fine.
When turning the key, the coil chatters, the starter will turn although slowly. seems like there is a problem with the starter, but when I put voltage to it straight from the battery it turns well.Any ideas? Thanks
