[email protected]
- Aug 16, 2018
- 1
I recently replaced the drive belt. During the process, I accidentally removed the wrong bolts on the transmission assembly which caused some oil leak from the assembly. As a result, I had to remove the transmission assembly and removed and refilled the oil. The lawnmower seems to work fine when the engine is running. However I noticed that it does not move freely as it used to be when the engine is off. Should I re-grease the rear wheel axle? Any advice is appreciated. Thank you
