I bought this Honda in the spring of 2014 to replace my Toro personal Pace mower. The transmission died on the Toro so I got rid of it. I mow a lot starting in February mowing tall fescue at least weekly. I bag a lot as I like the look better than mulching. I do like being able to direct some clippings to the ground or the bag. I have replaced the blade control cable this year. (I fold the handle after each use for storage and the cable finally broke). I am still on the original belt and tires! I have had to replace the front wheel bearings and the sleeves that hold the adjusters on to the body twice. This is cheap and easy to do. My hardware store where I bought it gets my parts in 3 days. replacing these items keeps the mower mowing straight. I change the oil twice a year and sharpen the blades about 4 times a year. If I mow in damp conditions, I tilt up the mower and wash out the deck. Grass will stick to the deck but not as bad as a painted steel mower. This mower mows very well but for mulching leaves it is not nearly as good as the Toro was so I usually use the bag to collect them. No problems on the transmission it is very similar to the Toro personal pace system. I run ethanol free gas that with stabilizer in it. I run the mower dry for winter storage. I am having some rough running now and suspect I need to clean the carb. I have the procedure and will probably do that today. Surprised I would have this trouble using better gas...My neighbor has the same mower but even older and uses ethanol fuel that is never drained from it and it still runs like new. This winter I will adjust the valves as the mower sounds a bit noisier than it used to and comparing it to my neighbors mine has some valve noise. His mows 1/2 as often as I do. So it has been a great mower. I started with the smaller engine metal body Honda mower for $399 and it just could not handle my deep thick grass and would clog so I returned it and got the HRX model. big difference and quieter also.
