diezelraccoon
- Feb 7, 2021
- 1
- 1
I bought a new Honda HRX 217 last summer. It’s been in the garage over the winter and had a little gas in it but it since evaporated. I filled it with gas and it must have taken me 30 pulls to get it to start but it will not run at low idle and only high idle but it surges. When I engage the blades it runs normal. I took the carb off and took out both jets and sprayed them out with carb cleaner including inside the carb itself. I also made sure all the holes in the main jet were clear. I put the carb back on but it still surges at high idle and dies when slowed down to low idle. At a loss with what the issue is. Any help would be appreciated.
