Honda HRT216 KS3A Throttle Cable & Lever Housing Mystery (17910-VE2-800 / 17851-VE2-800)
AYCRider
I have a Honda Harmony II HRT216 KS3A (serial MZCG-6324929) with a throttle lever that has failed internally. As a temporary fix, I drilled an external hole in the lever and managed to keep it working for a while. Unfortunately, the throttle cable has since deteriorated beyond repair, leaving the mower inoperable due to both the damaged cable and broken throttle lever.
My mower appears to be somewhat of a unicorn. It uses a standalone left-handle throttle lever housing with an upper-exit cable and a positive-action throttle cable measuring approximately 47 inches in length. From what I can tell, Honda may have pulled parts from a different design during this production run and then discontinued this configuration entirely.
After a significant amount of research, I was able to identify the original Honda part numbers as:
17910-VE2-800 — Throttle Cable
17851-VE2-800 — Lever Housing
Every Honda parts source I've contacted insists these part numbers are invalid and points me to 17850-VG3-D01, which is also what the Honda parts fiche appears to show for nearly all HRT216 models. I purchased the -D01 assembly and confirmed that it is not compatible with my mower. It uses a lower-exit, negative-action cable, and the cable itself is approximately 16 inches too long.
Another commonly suggested alternative is 17850-VG3-010, but its cable is about 3 inches too short and will not reach the carburetor.
Has anyone run into this oddball configuration before? If so, were you able to find a compatible replacement assembly, adapt another Honda setup, or source these discontinued parts from another supplier?
Any suggestions or firsthand experience would be greatly appreciated.
