Hello! I’m new to the forum and was hoping someone could help. I just bought a used Honda HRR1168VKA mower. It seems to run and cut fine, but when you disengage the blade, it makes a loud screeching sound. If I disengage the blade slowly, it doesn’t make the noise. Any idea what it could be? And should I be worried about it causing damage to the engine?
Thanks,
Jack
