Dear friends,
I bought used Honda mower and when I started it it was leaking in from carbaureter. So I replaced carbaureter and used once.
Gas leak was fine and then I used for while. Now, after few days I want to mow my grass but mower won't start.
I tried couple of troubleshooting but doesnt looks to be starting. I've one question for auto chock system.
I see there is no chord on my mower for chock not even wire. So just curious how my chock is getting used.
I removed air filter to see the position of the chock and its open position(like valve its in open position) is that correct? when engine is not running is that valve suppose to be open?. Is I'm missing something ?Is there a wire/or rod which connect choke. I red on internet that once engine heats up some thermostat closed the chock. But if the chock is already open how I can this be closed. What should be correct configurations here?
I'm just wondering since I bought used mower someone sold me with missing wire or connector for chock but do we've any such thing in automatic chock??
Any help will be appreciated.
Thanks R
Thanks R
