rbjenterprises
- Dec 30, 2016
- 1
- 4
This will probably be for Robert.
Honda HRR216VKA, Ser#MZCG-9501855, purchased 7/18/15.
Ran great for a year. This summer the rear wheels stopped rolling in reverse or if they did I was on asphalt. I have followed the cable adjustment procedure, pulled both rear wheels and cleaned the gear area. I have used a spring scale and it takes 40+ pounds of force to the wheels to roll backwards with the cable adjusted correctly or all the way loose. With the smart drive engaged the mower goes forward great.
I am finally getting around to fixing the problem, what next?
