Honda HRM215 timing setup help needed.
Kuy
This is re: Honda HRM215.
How do I set the timing of the crankshaft and camshaft inside of the engine block? There is a mark in between two gear teeth on the camshaft gear wheel but I cannot find anything that this mark should align with.
Please help me to set it up correctly?
Thank you in advance for any information.
There should be a mark on the timing gear attached to the crackshaft also.
Hey there - WELCOME to LMF!
I moved your thread to the Honda Forum. :smile:
