Honda HRH536 HXE blade clutch
lawnfixer
I am looking for parts for my UK Honda HRH536 HXE. Its a K2 2002 age model.
The blade constantly rattles when the clutch is engaged at low rpm and it goes a away a bit at full throttle,
the problem being the clutch plate bushings have worn and so has the metal meaning the fit is not tight with the blade holder anymore.
I therefore need at least a new clutch plate which i believe is the same one as the HR194/HR214 as shown in this ebay listing:
http://www.ebay.co.uk/itm/Clutch-Pl...-HR194-HR214-HRD535K1-Lawnmower-/330618768646
If someone could confirm this is the correct part then I can order it.
My bigger difficulty is the blade carrier which the clutch plate attaches to has two prongs sticking out which have both "grooved" as they have worn with the clutch disc.
I think a new clutch disc would probably work to fix the rattling but im worried that this worn blade holder would cause premature wear on the new clutch plate as there is less surface area for the carrier to contact on the clutch plate bushings.
Its difficult to describe but i will try and add photos later.
This diagram shows the parts i need which are labelled 18 & 4
Anyone who has information on these mowers please help me!
