Honda HRC215 SDA - Mulching options?
WaCanuck
I have an old HRC215. The mulching kit is no longer available but can find options for the mulching blade
BLADE, MULCHING (21") 72511-VA4-641. The plug and the other blade not avail. I have seen some reference to not needing the plug it will just fill up the back area with grass. Can anyone validate that and if so that top blade that goes with it. I find when searching on amazon options for the HRC216 with top and bottom blade. If I look for the parts individually i seem to find some options for HR215 but not HRC215. Last question.... The regular blade has a blade holder, is that holder still used for the mulching blades if can find the 2 blades or in the mulching kit it seems to indicate a different flat bracket? https://www.hondalawnparts.com/oemparts/a/hpe/505ce896f870022d24be0cca/mulching-kit
mechanic mark
Jakers1372
Hello, I’ve looked at both links. And I still am not sure of how to attach the blades in the correct order. I’m not sure if the new mulching kits spacer replaces the old metal piece, and where the washers go. Any help would be appreciated!
