How do you press the "washer" on to the cable under the engine?????
P PattyG Forum Newbie Joined Apr 18, 2016 Threads 2 Messages 2 May 17, 2016 / Honda HR214sxa roto stop cable installation #1 How do you press the "washer" on to the cable under the engine????? Attachments IMG_3161.JPG 156.2 KB · Views: 24
M mechanic mark Lawn Pro Joined Jul 15, 2013 Threads 175 Messages 7,482 May 17, 2016 / Honda HR214sxa roto stop cable installation #2 Wear gloves, line up spring washer to cable end, using a large flat blade screwdriver push spring washer over cable end working it all the way up, you can also use pliers to push spring washer on.
