Grayfather
Ran my trusty HR195 mower out of gas the other day. After refilling the tank, it wouldn't start. So, I turned it on it's side, pulled the carb bowl, found no obvious dirt, sprayed a little carb cleaner, and put it back together. Well, it started up just fine, but now it races (like it is going to blow up!) if I move the throttle off choke. Not sure what I did wrong. The only other thing I touched was the black petcock lever - moved it back and forth. I didn't touch any linkage or governor springs - so not sure how it has mind to go with an unlimited speed. Any ideas? thanks
