Honda HR194 Roller project
Hondajim
Hi, first post here so go easy!
I've just picked up the above model as non runner and have set about seeing what's what! Now this may seem very basic but the pipe between the tank and carb is completely broken and hence was never going to run. I have just ordered some 5mm internal diameter fuel pipe to replace it but sat here on my desk I'm wondering if it's actually a custom hose?
It seems much wider at the end that goes onto the tank and over the little fuel strainer. Has this just stretched? It is 8mm at this end or can someone point me in the direction if it is indeed custom.
Thanks advance,
Jim
Hondajim
Okay so I found the part number... 17512-ZE6-000
Could anyone help me with a UK supplier please?
