Hi,
I have been given a 194 mower which starts, runs , cuts but the problem is the blades are permanently engaged. On my old one the blades only used to engage when the black lever on the handlebar was operated, this one the blades are spinning all the time. the cable is fine, the lever down the bottom the cable operates is working OK. I have pulled the clutch that engages the blades off and there is nothing broken inside there. 2 questions, 1: is there a technique to putting he clutch back on ? It's a huge spring in there and I'm not sure if when I tighten the bolt that goes into the crankshaft I'm pulling the spring up or the release bearing is not pulling up properly on the crankshaft. 2: Any idea's why the blades will not disengage ?
Many thanks,
Andy
Many thanks,
Andy
