Export thread
Honda hf1211 wiring
#1
C
Christian1994
Was wondering.if anyone can help I have a honda hf1211 second hand and I need a diagram of the ignition barrel its a 5 pin and I have a red wire/ a white/ a brown/ two blues into the same head and a black any ideas and many thanks to anyone who helps 150238950590248420229.jpg
#2
EngineMan
EngineMan
I believe I can help you out on four of the five wires, but I would check to see where the wires go....!
White on S on the key switch from the PCB, Brown on the L on the key switch from the PCB, the two Blues goes on B on the key swtich one from PCB and the other goes to the relay, Black should be GND, the red wire is not showing on the wiring diagram anywhere near the key switch.
Here is a link to the wiring diagram...... http://www.motoculture-jardin.com/forum/detail.php?forumid=3&id=20832&p=1#181247
#3
J
juddycrust
Just tried it on my ignition switch , worked ok. Thanks
