Honda Harmony 216 timing belt
jim77
Hi,
I am looking for information on replacing timing belt on Honda Harmony 216
Welcome to the forum! :welcome:
I'm going to move your thread over to the Honda section to see if we can get you an answer.
Very good video of how to do it. Now wait for someone who knows if there is something special needed for your specific model.
youtube.com/watch?v=9bsAd9yD2WI
Hi,
First, do you HAVE to replace it? Honda does not specify any service or replacement for the life of the engine, so unless it is damaged, broken, etc. no need to replace it just as routine maintenance.
Here's a basic diagram of what the internals look like:
Not shown is the camshaft, which is driven by the timing belt....the two halves of the block come apart, so the crankshaft can come out and you can fit a new belt. Then, you align a set of marks on the cam pulley to set the timing.
If this is your first time doing this job or working on the internals of the GCV engine, I'd strongly suggest a Honda shop manual to use as a guide:
Honda Power Equipment Shop Manuals on eBay
Honda Power Equipment Shop Manuals on Amazon
