Sounds like it needs a carb cleaning. I'd recommend replacing the two gaskets between the carb and the engine block, new spark plug and air filter elements while you're at it.
Same thing my HR195 did. Main jet clogged in the carb with rust from water sitting in the bowl and rusting. Remove the carb and float bowl and Ill bet I am right
