FloridaRob352
- Feb 21, 2022
- 1
- 2
Engine idles fine at low idle. Give it throttle and it steadily surges. Engage the blade PTO and the surging stops. Pulling a plug wire off each cylinder causes a miss and stops the surging until replaced. Both cylinders identical effect.
This is what I've done:
-Disassemble and clean carb with carb cleaner and compressed air
-replace inline fuel filter and carb inlet filter
-replace air filter
-replace spark plugs
Any suggestions would be greatly appreciated.
-replace air filter
