Jwilson22071
- Feb 24, 2021
- 6
- 24
Had a Honda GX390 attached to a cement mixer show up at the shop. Found broken rocker arm and slightly bent push rod on exhaust valve. Customer just wanted those replaced and see what it would do. Put new parts on and everything seemed fine. Engine started 1st pull and automatically ran up to 4500 rpm. Shut down and reset governor- restarted and rpm is now 4000. The only way I can slow it down is by hand. Unit does smoke pretty bad but I figured it was gonna need a valve job anyway. Why can't I get the high rpm down?
