ClemsonHonda
I found a new looking pressure washer on the side of the road the other day so I snagged it. Got to looking at it today and discovered the key on the shaft that drives the pump must have worked its way up and wiped the shaft seal. I'd love to fix it. The motor still runs, but only if the choke is closed all the way. I cleaned out the carb 3 or 4 different times thinking that was the problem, but it still wont run right. I removed the pump from the bottom to make sure it wasn't locked up. Everything turns freely. I guess my question is, is it worth spending a few bucks on and the time to fix it? I'm not sure the the motor has any internal damage, because I dont know if the previous owner ran it after all the oil blew out the bottom. If i decide to fix it, Where would be the best place to find a few shaft seal and key? Thanks
