Honda GCV 160 LAO motor bent shaft.
Bmwz3coupe
neighbor has a bent crank shaft. Are all Honda 160 engines on walk behind mowers interchangeable? Same shaft length and diameter?
Auto Doc's
I think it is a matter of matching up the model and type information off the two engines to determine if they are compatible.
Mower manufacturers do not always have the same engines options. Basic displacement might be the same, but that is about it.
