I've got a Honda gc160 on a log splitter, that won't start, all of a sudden. It's about 8 or 9 years old. It was working fine a couple of days ago; I split half a cord with it. I was able to download part of a shop manual for it. I did the following things:
Checked:
Replaced fuel with brand-new fuel; including carb. bowl.
Good spark. A White spark. Probably good magneto then; and related cable/wiring.
'Oil-alert' should be okay because I have spark?
Oil level is good.
Spark-plug is seated/tightened correctly now.
Throttle 'Kill switch' works.
Muffler good/ no blockages. (no spark arrestor, by the way).
Main fuel-line & fuel strainer is good (Bottom of the gas tank P.92); no blockages.
Air filter checked out fine.
It pulls fine (pull rope). It appears to be delivering fuel. The plug will be wet, if I choke it and give it 4 or 5 pulls. It used to start in 2 light pulls, every time. I tried using some starter fluid and it still doesn't start.
I'm wondering if I should pull off the valve cover and take a look at the valves or maybe pull the carb?
Checked:
Oil level is good.
