Honda clutch cable
Humphrey
I have a Honda model HRB 215-HK and the clutch cable came un-mounted(bolted) from under the lawn mower. Couldn't figure out where to re-mount it. Thanks
bwdbrn1
Do you mean an HRB215 HX? The one with the hydro transmission?
The ball on the end of the cable goes into part #6 in the diagram, and the cap on the end of the cable sheath goes into part #9.
Humphrey
Both ends are still attached, there is a cable hold down lug, which hold the cable from moving when
Shifting from fast and slow or vice verse. It seems like a bolt/screw is missing. Model : HRB 215 - HK. Serial number: MZBA-6323879 Thanks
