I have a Yard-man Model Series 556 with a 6.5HP Honda engine. Model 12A-556Q713 Engine S/N GJAAA-1310318.
From the numbers it appears this is a Honda GCV190. This mower was given to me by my father-in-law because he could never start it. This is the first lawn season I have used it for and it is a chore to get it started. Once the engine has run for a while though, you can shut it down and it will start up every time on the first pull. The trick is just getting to cold start. Before i put this thing up for the winter I want to try and get it start properly
I thought maybe it was the Carb so I pulled it apart and cleaned it per this video Honda gc160 gc190 carb rebuild gcv160 PART 1 of 2 - YouTube but I didn't notice much difference.
I found that if I pushed in on the top of the governor and had someone pull it, it would fire and could maybe get it to start in 3 or 4 pulls doing it this way.
Im wondering if its some kind of issue then with the auto choke? All these added Auto features just end up being more a PITA it seems. If anyone has an idea on what I should be looking for I would appreciate it. I dont have much experience with governor/auto choke setups.
