Randy Boyd
- Jul 19, 2018
- 1
- 1
i have a honda 3011 riding mower,recently while mowing i ran into a bush and caught the shift lever and the mower stopped going i assumed it had kicked into neutral but it hadn't so i tried another gear and it would lurch slightly but wouldn't go forward i continued until it started moving but if it met any resistance ie uphill ect it would stop again so i put it in reverse and moved it to my garage and i tried to get it to go forward but it won't move only slightly as you put in different gears could it be the clutch or just an adjustment on the shifter cable?
