Nakwasina17
- Aug 12, 2013
- 1
- 1
I have a one year old Troy Bilt lawnmower with a 160cc Honda engine. It ran fine last summer, but this summer it surges. I have removed the carb and sprayed every orifice with carb cleaner. I unscrewed the main jet but couldn't get it out of the center housing. When I removed the fuel line after the shut off valve, there was very little flow, so I cleaned the fuel filter and that improved things a lot. But, the engine still surges and just doesn't run with full power. Really baffling. I would appreciate any suggestions..... When I reinstalled the carb after cleaning, might I have gotten a gasket in the wrong way and so the fuel:air mixture is off?
