Lachiepower0402
- Aug 14, 2014
- 29
Sorry I put this in the wrong section, I didn't click the right section.
I have a homelike 25cc whipper snipper that I picked up from the side of the road. I have cleaned the carb in fuel as it was in disgusting condition, put a different spark plug in that sparks. Cleaned the fuel out and put new fuel in it. I also put new fuel line, fuel filter and primmer bulb as they were all cracked.
So I tried to start it and nothing, took the spark plug out, turned it upside down and pulled the rope to see if I flooded it and still nothing.
Then I dipped the spark plug in fuel and put it back in and pulled the rope and nothing.
What the hell is the problem, the piston sounds alright when it is moving up and down, could it be an air leak?
Also does it matter than I am using 50:1 ratio fuel and it is designed for 25:1.
