I have a Tecumseh HM80 motor with a points ignition that has a very weak spark that I traced back to a “dead” magnet in the flywheel. By weak I mean it will not even hold a small screwdriver from the magnet. Is there anyway of replacing the magnet or having it recharged? The magnet is not glued to the flywheel it looks as if it is fastened by means of two pins or dowels.
The motor is from an old go kart for my grandson for Christmas. Thanks
Jack
Jack
