HM 80 upgrade
Mattmotors
HM80 155128C Serial 62160
Hi all , I have this 8 horse Tecumseh on a 1977 Ariens 32 inch snow blower. My dad got it when I was 18 and I'm still using it at 65.
What I would like to do is put heated grips and maybe a light on this machine. I currently have points and condenser on this engine.
If it can be done, I'm sure I will need a new Fly Wheel, Alternator and Coil Pack If it will even be able to bolt on to the block. Would it be cheaper to put a well equipped Predator engine on if one will match up? Or should I just get a good pair of gloves and a magnetic light from HF.
Please let me know your thoughts. Thanks , Matt.
To upgrade this unit you would need to find an engine with at least a 10 Amp charging system. Your idea is good but unless you have excess $$$$ the unit is not worth it. I suggest you get a pair of heated gloves and the brightest headlamp you can find. Use the balance of your $$$ and have a strong hot toddy when you’re done blowing.
