High effort to pull start my 2-stroke blowers
MowerMike
Recently my two 2-stroke blowers (Echo PB-250LN and Hitachi RB24EAP) have been requiring very high effort to pull the starter cords. They feel like super high compression large 4-strokes where I can clearly feel every compression stroke as I pull the cord. Once started, they both run fine, revving quickly and running cleanly at full throttle. I'm using high octane ethanol free Trufuel synthetic premix gas, so I can't imagine that I've developed any carbon buildup or carb clogging. For the first few months of use both blowers required very little effort to start, so I'm at a loss as to what has caused them to become so hard to pull now. Today, I could barely muster the strength to start the Echo, and initially it almost felt like it had seized.
Mad Mackie
I've never been a fan of premixed fuel/oil products, just my opinion. Two cycle oil and gasoline do not stay mixed although the color of the mix may suggest otherwise.:thumbdown:
I would stop using the premixed stuff. Remove the spark plugs and look into the cylinders and pull the motors thru without any compression. :confused2: The increase in drag while pull starting is not a good sign!!!:frown:
Mad Mackie in CT:biggrin:
MowerMike
According to the manufacturer (TruFuel), they don't use regular petroleum based gasoline and the fuel does not break down over time. So, fuel / oil separation should not be a problem.
Mad Mackie
I've never heard of TruFuel, but with both of your two stroke engines doing the same thing with this fuel, I think that the message they are giving you is that it may be too late with that much drag probably on the cylinder walls!!! I would stop using TruFuel!!!
Mad Mackie in CT
MowerMike
I've never heard of TruFuel, but with both with both of your two stroke engines doing the same thing with this fuel, I think that the message they are giving you is that it may be too late with that much drag probably on the cylinder walls!!! I would stop using TruFuel!!!
Mad Mackie in CT
Have you ever heard of Stihl MotoMix ? It is basically the same product as TruFuel (same base synthetic fuel with different synthetic oil) that is sold through Stihl dealers and endorsed for use in all Stihl 2-stroke engines. In fact, Stihl thinks so highly of Motomix, that they will double the factory warranty on their Stihl 2-stroke tools if you use it. Do you think Stihl would sell it if it was damaging their engines ?
motoman
I have used Poulan synthetic oil for 2 stroke mix on my trimmers and chainsaw with great luck. The chainsaw typically sits a year at a time and this year a tree came down and I needed the Husky quick. It was very difficult to turn over with the compression release. I did not take it apart , but concluded rust must have formed on the cylinder even stored inside as I had not shot any storage oil into the cylinder. Your situation sounds different. Be careful to follow the mix ratio. My chainsaw wants 50:1, while the trimmer wants 35:1. Two strokes will seize if not properly lubricated.
MowerMike
Thanks for the info. Both blowers specify a 50:1 gas/oil ratio and the TruFuel premix I'm using is precisely 50:1. I'm also using TruFuel 50:1 in an Echo PE-225 edger and SRM-225 trimmer, and so far I've not had any problems. The edger and trimmer are smaller displacement engines and have i30 starters that reduce starting effort by 30%. All my gas tools are stored in a dry garage and the blowers have been used regularly since early this year. I don't want to use ethanol gas in my 2-strokes and there is no place nearby where I live to buy ethanol-free gas.
exotion
Run some seafoam through the machine through the plug hole follow the directions
Mad Mackie
I haven't noticed that fuel at either of my Stihl dealers, but I wasn't looking for it. One dealer has ethanol free 94 octane fuel in 1 and 5 gallon containers and the same fuel with a premix at 50-1. A 5 gallon can of premix is $80 !!!!!! WOW!!!!
I have 3 Husqvarna chainsaws, 1 Stihl 2 stroke trimmer, 1 Stihl 4 stroke trimmer, 1 Stihl 2 stroke hedge trimmer, 1 Stihl 4 stroke BR 600 back pack blower. I use 89 or 91 gas with 10% ethanol and swap back and forth between Stihl and Husqvarna premium 2 stroke oil. I also have 4 machines with Briggs engines, a machine with a Kawasaki and another with a Honda and all get 87 with Star Tron. I no longer use StaBil as it doesn't work with ethanol crap fuel!!!
BUT, if your 2 stroke machines are getting increasingly more difficult to turn over, then something is wrong and I think that it is the fuel/mix that you are using!!!!!!
The next time I'm at either of my local Stihl dealers I'll check out the Stihl fuel mix.
I also use SeaFoam and I think that it is a great product when used in the correct application, which has already been suggested to you.
Mad Mackie in CT
Rocketman
Why are you using high octane fuel? I am fairly sure that all you really need is 87 octane regular. I am not sure this is why you are having problems starting the blowers, but I never use high octaqne fuel in any of my equipment because in my opinion it is not needed in anything but high compression performance engines. You actually get a faster burn during combustion with 87 octane!
Stabil does make a fuel stabilizer for ethanol gas and has worked well for me, so I would try that with 87 octane and see what happens!
