hi
peteslawns
have come across an old morrison triplex with a 12hp honda motor looking for any information especially a wiring diagram , (NZ)
Something like this?
Morrison Triplex Series III Ride On Reel Mower | Trade Me
As one of the Honda guys here, I can help you with the ENGINE questions, if you can tell me which Honda engine is on the mower. Really best if you can find the engine serial number, which would be stamped into the block, usually in the form of "GXXX-1234567" With that, I can pull up a shop manual, parts list, service bulletins, etc., but again, only for the Honda Engine.
I'm hopeless with regards to any other part of the mower, sorry!
Re:motor info
the same as the one in the link just no where near as tidy ,engine is GV400 2074844. it has no spark so i am after a coil, which is proving a little hard to track down
thanks for your time
I punched in that engine serial number and you are correct: The coils used on that old engine are long gone.
Both the ignition coil and coil assy. (battery charge?) have been discontinued for a long time now.
Best bet is to try and find a donor motor with usable parts. Best of luck!
charging coil is all good replaced ignition coil with one from a car runs sweet few adjustments to do on carb and it be a minta
