Hi new to board with a question
T-LeDoux
Hi I am retired and tinker with small engines as a pass time. My son works at a scrap yard and I go get parts off old engines they get in. My question is they have a Briggs 18.5 I/C engine I picked up for the carb,But was wondering would it be worth rebuilding, They cut off the pulleys so it will need a new crank. Thanks for your input. Family-YBSXS.5012vp 274826 model-31N707 Type-0233E1 Code 0311177E
Let me repeat a post from another thread that might just get you the help you need. Please follow it.
Since this is a help forum, it is only fair that the people trying to answer questions have some information to work with, so they can give an accurate answer. This helps them if they need to research parts or service information on your engine or equipment. In the first part of your post please include your engine numbers from the ID tag or stamping and the equipment type and model numbers that are on it. Failure to do this may result in you not receiving any accurate help with your problem.
Many of the tech's that hang out here work in or have there own shops and the first thing they do when they make up a work order on a unit is include the engine and equipment numbers on the work order. Since this technical forum is offered free to the public, it's the least we can ask you to do, so please help all of us out. *So please post the numbers in the new topic you start to ask your question. It should be the first thing you write before beginning your question. :D
T-LeDoux
OK Sorry for not giving info. Family-YBSXS.5012vp 274826 model-31N707 Type-0233E1 Code 0311177E
Crank costs $180' gasket set costs $61. Don't know about piston and rings. Your call.
chance123
Is this a duplicate thread?
I think that there are three posts on this engine and subject.
